Hi, i've got a 06 Civic 5 Dr EX. At anything over 35 - 40 mph there is a constant rattle from around the passenger A pillar. Any ideas on where this may be eminating from and on a fix?
Davy
My 07 had a rattle at the drivers side. Turned out to be the plastic shroud round about the wipers tapping and scraping the windscreen. I jammed a tiny bit of paper under mine and silence since!
no unfortunately not. My daughter seems to think that it is coming from the centre console / centre dash area.
Here is another suggestion I found out about. Apparently there is a known issue with plastic clips being left around the windscreen during production, which are meant to be removed. They are for guidance when fitting the windscreen but sometimes get left then begin to rattle about. Tell your dealer to check this - they should be aware.
stu
