hi there
i am new to this site, so i hope someone can help.
i have a 1999 civic coupe ls, and the air con is stuck on, even when the heater fan is off, the compressor and heat exchanger fan are still on, there are 2 relays in the fuse box for the compressor clutch and heat ex fan, both these relays are ok, after a 40 mile journey on monday i had ice in the passenger footwell and the air through the vents was freezing cold, i have to turn the heater up to be comfortable!
anybody any ideas?
is there another relay between the button on dash and fuse box?
if so where?
cheers
ian
does the button light up? and turn off when the switch is off?
could be something easy like a faulty switch.
unplug the switch (will default to a/c off)
hi guys
yes the button lights up when in the on position and the light goes out when in the off position as normal.
i have pulled the relay for the compressor clutch in order to turn it off for now, however i would like a proper fix.
cheers for your responses
ian
