The problem is with a 2001 Civic 1.6 S 5 door. The compressor engages for about 15 seconds then disengages, then cuts in again maybe a minute later but only ever for 15 seconds at a time.
It used to work fine up to a couple of weeks ago. I have used a parts shop pressure tester and top up kit to check the gas pressure, but this is fine and gives a reading of 35.
I've checked the mag clutch relay and this is OK (swapped out for another relay the same but no difference).
Any ideas what could be wrong and how to diagnose?
