Morning chaps
I cleaned the egr valve on my wife’s civic as it was blocked solid and also changed the fuel filter.
After doing the egr I started the car up just to check all is ok, it took ages to start as there was excess brake cleaner in the piston bores to burn it rattled a lot and revved by itself I gues using the brake cleaner as fuel, half way thru trying to fire up the engine light came on and now it won’t go it says P1834 which is system malfunction. Even when I clear it it comes back instantly within 5 seconds and car is in limp mode.
Any ideas?? I can’t drive it As it is now poxy thing.😔
