1 - 10 of 10 Posts
what parts will i need oviously the engine and box what about ecu,driveshafts,mounts, ect ect thanx ollie
and is the electrical bits confusing im not to good with electrics
also are the engine mounts the same do i need a vti rad ect
can i jus unplug the lsi ecu an the b16 one in ect thanx
is yours an eg? if so you will need to change to a vti rad as the hoses are bigger, also you will need to use all the mounts off the b16 as the front gearbox mount wont work and also the a/c mount off the lsi motor wont work (different screw patterns) the ecu is a simple pull out plug in but keep in mind if yours is ocd1 get a ocd1 motor it makes the electrics easyer! and the loom just plugs back in again the 2 connectors on the drivers side and the 3 on the opposite! if your car in a ek dont take my advice as im only advising on the eg.
1 - 10 of 10 Posts
