i bought a 1.4 ek as a project i just got it running today for the first time as it had a flat battry ,
the boy tht i bought it off said it was running on 3 cylinders
as i said i just started it tonight and it sounds like its running on 3 cylinders ie miss fireing
but it doesnt rev over 3000 revs and it doest idle
anyone know what the problem could be and how i could fix it
i done flash codes and nothing is coming up either
i was around to gillans house and had a look at it before its the sensor on the throttle body the tps sensor
if you have the lead on or off it doesn't make a difference to anything so the sensor must be fucked plus the eg5 whn i put the new engine in did that but i swaped the sensor for a new one and it was working proper again
worth giving it a try????
